Can anyone share their knowledge on the winterization of a 5.7 GSI volvo duo-prop with captains call exhaust? I have found 4 drain plugs port and starboard, Manifold and block. I drained raw water pickup pump, and the outdrive is down and covered and wraped.<br />I usually run engine out of gas in carbs and fog engine with marvel mystery oil, can I do this with a fuel injected one, I filled tank with 93 oct amoco and added stable to the tank and ran to get treated gas throughout system. any other suggestions?
