Hello again,
This is sort of a continuation of a former thread I started about a week ago (33hp Evinrude-enough power?), regarding finding the proper motor for my 1965 15' Reinell Runabout. I may have found an engine that would be suitable, but being new to boating (and boat motors), I would like to ask your opinions.
The engine in question is a 1983 Suzuki 50hp DT50EL (2 cyl, 2 carb, 2 stroke) with low hours, electric start and forward controls. Price: $1500. Weight: 183 lbs. According to the original owner, this engine was designed for salt water applications even though it has only seen fresh water (????? - I didn't know engines were specifically designed for types of water)! Don't know if that's good or bad.
What do you think of this motor...and do you think it's a good choice for my old Reinell? Good realiability? Easy to get service/parts? Light enough? Powerful enough? I only plan on using the boat for pleasure cruising on fresh water lakes and rivers. Max. people onboard- 4.
Thanks in advance for your thoughts!
PS: I also found an old fresh water 1965 Mercury 50hp for $1500. Better choice than Suzuki? The older Mercury would match the vintage of the boat.
