How do I mount my transducer on a pontoon?
chriso076
I need to know the best way to mount my transducer on a pontoon boat so it will work at speed which of course is not real fast. I,m a little hesitant to drill in the pontoon but if this is required, What is the best way?<br /> Thanks for any help!<br /> Chris
seaman
Re: How do I mount my transducer on a pontoon?
never have done that but could you try running some kind of bracket down below the water line and mount your transducer to that sounds like that is a way?
fone_man
Before I would drill a hole in a pontoon...<br /><br />I would get a very large worm clamp (stainless) & attach it that way. You might have something to connect up with smaller clamp, I don't know!<br /><br />But that is were I would start...<br /><br /><br /><br />------------------<br />"Keep it between the Bouys & Good Luck"<br /><br />fone_man
corm
We weld u shaped brackets on the back of the toons and mount the ducer on them.<br /><br />corm
