Re: "frozen" steering cable @ outboard
What posion is the cable stuck retracked or exstaned. Use as much white vingar as you can get into the tube and let it soak in,than pentrating oil, if you have a slap hammer attahe it and go to it,or a raw hide hammer, hammer and wood once you break it loose you can work in some marine grease.You should allways clean and grease,change oil,before winter storge (when not in use always keep the engine turned so cable is retracked)
