Central FL Mike
- Sep 3, 2006
- 15
I have a 1993 Johnson V6 150HP Silver Star Series outboard. After researching replacement props I found that a lot of V6 and V8 engines were lumped together along with commercial engines. It seems the only difference may be the gear case size. Is there any way to tell if my outboard is a commercial model using the serial and model numbers? What is the difference between a commercial and non-commercial engine?
Mod: J150ELETR Ser: G03175782.
Thank You for any input.
