Re: etec vs mercury verado
e-tec, for me. Repowering a 20' "toon", this spring, in the 75 HP range.<br /><br />Weight is an issue with this toon.<br /><br />Technology has given us great lightweight 2-strokes. 4-strokes are meant for cars, in my opinion. <br /><br />Why?<br /><br />1. Four strokes need hot temp's to burn off combustion waste (blow by). 160 degrees (F), burns off-NOTHING.<br /><br /><br />2. Four strokes, even in I/O and inboard applications, fight internal corrosion because of #1.<br /><br />3. #2 becomes more of an issue with so called "lightweight" four strokes because of all aluminum contruction, etc.<br /><br />IMHO, four strokes are fine, and best serve, in a "closed" environment where they can burn off #1.<br /><br />Even a "marininezed" small block Chevy is an anchor, waiting to happen, without a "closed" cooling system.<br /><br />When GM stops building their "anchors" already done, there will be nothing but aluminum blocks. Those require closed cooling systems-to live.<br /><br />Prices go up, outboards look more attractive.<br /><br />The 2-stroke technology is there. Lack of maintenance KILLS 2-stokes.<br /><br />The same, lack, will kill an aluminum four stroke-QUICKER-IMHO.<br /><br />With all of that said, Americans will maintain a foreign named outboard, according to spec's. They will not do so for an American named product. I've seen it, I can PROVE it. The same goes for cars/trucks, etc.<br /><br />An Evinrude "four stroke-built by Suzuki) will recieve far worse maintenance than the Suzuki branded product. Again, seen it to be true.<br /><br />The point is "will". Americans see NO value in an American name. That's another topic.
