Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Year of my Evinrude 35 HP motor?
  • Year of my Evinrude 35 HP motor?
    Can someone help me with the year of my Evinrude 35 HP motor? The serial # is E0001724, and the Model # is 3565S.Any help appreciated.
    Re: Year of my Evinrude 35 HP motor?
    No model 3565S listed, ReggieModel 35652 is a 1976 35HP. Could that be it?Good luck, and welcome to iboats.
    sigpic
    • #3
      It definitely has the "S" at the end, but you are probably right about it being a 1976 model. It is light mtallic blue with a blue and white cover and "Evinrude" logo on it.Thanks for replying so quickly.Reggie
      • #4
        You appear to be short a digit then. Would you mind double checking?A 3hp engine would have for numerical digits, but there's no model 3565 3hp engines. Occasionally we do see incorrect, factory model numbers here though.
        • #5
          No, that's definitely the model number on the engine mount. Is there some other place I can look for a number?
          • #6
            Well, it's easy enough to confirm it's a '76. Follow the spark plug wires. The should go into an igntion coil. Follow the wires that come from the ignition coil. If they lead up underneath the flywheel, it's definitely a '76. If they go into a plastic "black box", it's not.The '76 hood should have a decal that says "Evinrude 35" on the side, but hoods get swapped & repainted all the time.If the spark plug wires don't go to an igntion coil, but rather up underneath the flywheel, we're way off and we're looking at a '59 35hp, or possibly even a '60-'62 40hp engine. We can narrow from there.
            • #7
              The spark plug wires go into two small creme colored electronic boxes. If that helps any. Sorry so long to reply, We're dealing with the evacuees up here.
              • #8
