Re: wiseco pistons
All of the new series Wiseco pistons have been manufactured to fit the std over-bore sizes.<br />For a .020 piston, the block is bored .020 over STD, not .021 as it used to be. The only case I believe you will want to go over, whether it's .020, .030, .040, etc., is if high performance features are incorporated which would generate higher temps.<br />The Wisco expert is Dhadley, but I would recommend going with all pistons of the same manufacturer if possible.
