Re: skeggard
Hi,<br />I also have to use my boat in shallow water when running to/from the lake where I use my boat. Last summer I hit a sand bank in planing speed in the river and I came to an halt in 2 sec... My depth sounder showed 40 cm (1,5 ft) then.<br />Result: prop was "sandblasted" and most of the black paint disapeared, on the skeg also much of the paint was gone but skeg itself was in one piece. It is difficult to know where the sand banks are from one day to another since they move so it is a risk I take. <br />It is difficult to have patience to use low speed (long time) to reach the lake, usually it is planing speed I prefer. Actually You do not need much clearance under my boat to cruise without problem in shallow water, but I would not dare to do this unless I know it is soft material like sand/mud etc in sea bed in this river. With my old boat I had before I hit a rock once (in the lake, not in the river) and the skeg saved the prop then and I got a 10 mm (1/2 inch) dent in the front of skeg - no problem to repair. But that is the only hard object I have hit during the years. <br />There is also a danger in the river here with old timber sitting in the mud/sand and sometimes they rise and is a great danger (it can hit the hull but usually no problem if you hit the timber in same direction they are tilting in but if you hit it in from other direction it is much more dangerous). They used this river before as a natural water transportation road for timber and let it float from the nothern part of the region to the south part in to the lake. It was maybe 20 years ago they ceased with this activity but there are still much timber in the river that is sitting in the mud and sometimes rise to the surface with one end. 2 years ago it was very low water in the river and lake and it was interesting since then You could see much more of this old timber sticking up and some places where I regular cruise at planing speed so I have to be more careful there now... <br />Maybe a forward looking sonar can help some. But I'm not sure after reading some test of Echopilot and Interphase Probe.
