Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Using an outboard in freezing temperatures
  • Using an outboard in freezing temperatures
    I use my boat for walleye fishing when the temperatures go well below freezing. My concern is water left in the lower unit or block freezing and causing damage. Is there a product I could use to flush the lower unit after use such as an RV antifreeze? My thought is to displace the water with a solution using muffs. I have seen a product (biodegradeable)for winterizing a boat at the dock, but I contacted the manufacturer with questions and they don't respond.
    Re: Using an outboard in freezing temperatures
    As long as you store your engine in the upright position, you will be fine. There will be no water in it to freeze.
    • #3
      As long as you park the boat on the level and not uphill, and keep the motor in the down position you should be just fine...I use outboards thru the winter with no problems yet...knock on wood
      • #4
        I agree with lubeude and Chief, JUST BE SURE to keep the outboard down and not in the trailer or tilted position. YOu also want fresh lower-unit oil, if you have old oil with water it can freeze.
        Mes amis nous allons quelque part dont tout
        le monde
        Se rappelle d'un endroit ou l'herbe etait
        toujours verte
        Et la fete ne s'arretait jamais
        A autour du rocher
        • #5
          I don't know the correct answer, but here's my experience from last winter.My boat (the aluminum job with the single Honda main and small Honda kicker) in the slip. Note the very stiff water... ...another view. Here's the 130 in a close up... ...and finally what happens to the anchor when thrown overboard. Mind you, this is saltwater. Anyhow, both engine still work fine. One down, one stored up. Maybe I got lucky? It did take a long time before the 130hp motor started to 'pee'! I do believe I was the first to break ice that day.
          • #6
            Why use the boat??? Just walk, or better yet drive!!!!!!
            ACTA NON VERBA​
            Back to Top
