Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
suzuki/evinrude/johnson prop swap
  • suzuki/evinrude/johnson prop swap
    Will all 13 spline 4 stroke 70hp evinrude/johnson 13 spline props fit suzuki 4 stroke DF70?
    Re: suzuki/evinrude/johnson prop swap
    My Johnson (Suzuki) 140 4-stroke has a 15-spline prop shaft. All Johnson 4-strokes are made by Suzuki. Same spline as the Mercury 115 & 125 HP 2-stroke. Merc props will work on mine with the right washer/spacer. Count the splines on your engine.JD
