Dale Albert
- May 29, 2004
- 3
I'm not new to boating, but I am new to boat ownership. I'm looking at a 1995 17-foot fiberglass bay-boat hull with a 1994 Merc 125 HP OB Redstripe attached. The current owner tells me the original motor on this hull was a 1995 but was stolen as soon as the he bought the boat, so replaced it with a 1994. I understand that the Merc reds are fresh and the blues are saltwater. What's the difference in construction between the two? I plan to run this boat in saltwater (I live in Tampa, FL). Will this freshwater motor rust away overnight after a day of slat spray, even if I wash it down religously? The boat doesn't seem to have been used much and looks sound. There are signs of wear on the aluminum prop (deeply scored, leading edge is chewed up), the lower unit oil looks good, I haven't checked compression yet. Som of the bolts on the port side of the powerhead have begun to rust, as has the lowest spark plug. Everything else under the cowling looks good. Will this motor hold up in the salt?
