I have a 1987 85Hp.Force, my question is, is the sender a on/off type, or is it a variable voltage sender that will work with a dash mounted gauge, the sender that is on the motor, is a reddish-orange plug held in with a snap ring, the manual that I have just gave test instructions to check if it was working. If not a variable output sender, any suggestions on one that will work?
