Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
how long before water should start coming out piss tube
  • how long before water should start coming out piss tube
    100 hp mercury motor how long should it be before you see water coming out piss tube. trying to find out if water pump is working . bottom pisser is working but not sure if top pisser depends on thermostat
    Re: how long before water should start coming out piss tube
    Don't know about your Merc, but my omc comes out in a few seconds. Yours may be different. Are you running it on Muffs? It can make a difference..
    Rick
    "Boating is Life...All the rest is just Details"
    2007 Bentley 200 Cruise
    2007 Merc. 90 4 stroke
    • #3
      yes I was running it on muffs I just want to make sure I do not do any damage to the motor is there a way to see if water pump is working ( this is a new to me motor i have used Johnson in the past
      • #4
        Hi,When You run with muffs on the waterintake(s) make sure you have enough waterpressure from the watersource. I know when I have used muffs and not opened the watertap enough there was no water coming out of telltale at first.That is my experience with the outboards I have used and the muff that I use.If top telltale depends on thermostat:On the outboards I have used there is water from telltale almost immediately. So I do not think it depends on opening of thermostat, but I do not "take poison" this is the case for all outboards.You can try to run a wire up the telltale hole to find out if any obstructions, could be as easy as that why no water is coming out of telltale.Good luck!/Bo
        • #5
          when i run either of my 3 evinrudes, water comes out within a second, and on my 50 hp, water comes out even while cranking......some motors are a lil diff, just thought id add my 2 cents
          • #6
            ditto phatmanmike's response, my 50hp evinrude will spray while cranking, but the merc i had didnt start spraying good until you reved it up a little.
            Back to Top
