Re: 1995 Evinrude 150 Ocean Runner
Hi Spork,<br /><br />These engines were very good, if well taken care of. Just like most! I can't say firsthand about performance, but I can give you a link to another discussion here on I boats that I found. I'm sure others will chime in with opinions. The weekend is pretty quiet around here. Check compression, Lower unit fluid for water intrusion(Milky) and check the Tilt and Trim for proper operation. A sea test is a must! At least hear it run! If they won't let you do that, don't buy it. If it's off the boat, about the only thing you can do are the tests I suggested. Good Luck,<br /><br />
web page
