mickjetblue
- Aug 23, 2007
- 509
The pic is not the best, but it shows how I made this contraption from 2 small pieces of outdoor 2 x 4, and 1 piece of hard yellow pine.
A hardware hook is screwed into the front of the base of the "assistant". A few wraps of gorilla tape on the hook are used to take the grip bite
where the hook grabs the cowling. Visualize that the small stand is an outboard motor,
and that the hardware hook is underneath the cowling handle, and you will get the idea.
The base 2 x 4 is 8" long, and the 1 x 4 yellow pine is 35" high. Note the hole for a thumb grip at the top.
A second piece of 2 x 4 is cut to 45 degree angles and screwed to the bottom and upright piece for rigidity and support.
Not visible, but on the bottom 2 x 4 is a piece of rubber backed carpeting epoxied to the base bottom.
I tested it on my boat prior to the snowstorm, and it works great. The measurements can be customized to a person's size,
and their position used when raising/lowering the motor. Some things needs need to be "felt out" and measurements taken.
I can say that this works fine for me as an "assistant" for leverage, but cannot make any guarantees otherwise.
Happy tilting!
Happy tilting!
