- Jul 18, 2011
- 17,711
My recent running of my Mercury 7.5 HP in a somewhat wobbly trash barrel has prompted me to think about getting/making a motor stand. So, I worked up a design last night and headed off to Home Depot first thing this morning.
The design is pretty basic . . . requires only 3 (three) 8 ft 2x4 pieces of lumber.
There are 2 cuts to each of the 3 2x4's . . . to yield 6 3' pieces and 3 2' pieces.
Making the main portion of the stand . . .
Here is the stand set upright and positioning the lower rails . . .
I put in a single screw on each side, so that I could tilt the stand back a bit, reflecting the slope of a transom.
Then I secured the stand in the sloped position and measured and cut the rear angle supports (which are made out of the remaining 2 3' pieces of 2x4).
Done . . .
Here is my Mercury 7.5 loaded onto the stand. I made it high enough so that it can take a long shaft (20") motor as well as the short shaft.
I figure that it can easily hold upwards of a 150-200 lb motor . . . maybe a larger motor with a cross brace on the main portion of the stand.
It took about 1 hour of work to make this stand. . . . about $10 of wood and another $10 or so in hardware (deck screws . . . 3" & 3'1/2" ).
Done . . .
