jackrabbit66
- Sep 26, 2014
- 58
19' Seasport dual console / trailered & covered
Tohatsu 120hp 2 stroke outboard / tilt down
I live in North West Florida where the temperatures rarely drop below freezing. Because of this i don't do much winterization on my boat. Because I can still get out on the water some days I simply start the engine once a month and let it run for about 5 minutes to get the engine up to running temp & I make sure the steering rod is lubricated. Is this going to cause any problems for my battery or outboard? Is it necessary to give the battery a trickle charge? At what temp should I be concerned about damage to the outboard?
Thanks!
Thanks!
