1983 bass tracker tournament tx 80hp mercury motor. My front spring loaded toggle switch to raise and lower my motor quit working. My trim and trailer button on throttle control works fine. I can't figure out where wires go from toggle switch. there is a violet wire on center terminal on 3 wire toggle switch which i can't trace to anywhere. I have an internal hyd. pump in boat with 2 solenoids. is it possible they go to throttle control where my trim switch is located? i tried putting 12 v on center terminal of switch nothing happened. any help would be appreciated.
