Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Need to build outboard motor stand: Any plans, pics, suggestions?
  • Need to build outboard motor stand: Any plans, pics, suggestions?
    Well, I'm about to build an outboard motor stand. Anyone have any good suggestions on an easy, uncomplicated, and above all, cheap approach to this?Any pics, plans, etc. will be appreciated!
    Re: Need to build outboard motor stand: Any plans, pics, suggestions?
    I'm getting ready to build one as well as I need to pull my outboard off so I can re-do my boat starting in a couple of weeks.
    1996 18' Premier Odeski Tri-Toon w/ 120hp Force
    1964 13' Boston Whaler Custom Center Console with 1986 Merc 35
    2004 Honda Aquatrax F-12x
    • #3
      ..oops: wrong forum for this post. Plz move to the right one.
      • #4
        Member Djohns19 made this slick one. Only thing I would add would be a small boxed in parts shelf on the front side.
        Rick
        "Boating is Life...All the rest is just Details"
        2007 Bentley 200 Cruise
        2007 Merc. 90 4 stroke
        • #5
          Doc I don't know how big a motor but for my 15 Johnny I built a simple bracket and lagged it to the wall of my garage. I claimed a corner where I made a 7 rod rack on the wall, my kicker, and an old dresser that hold electronics, lines, various tackle etc, between outings. The motor stays there if I won't troll all day and winters there as well. Works well for me and I'll send apic in a day or two if I can figure that out.
          • #6
            RickVery creative that Djohns... Just a few pieces of wood and a few bolts. Looks great.BTW Maybe there IS a parts box on the other side.
            • #7
              Thanks Rick for the pic! Already sketched mine out based on it.I thought of doing what you did Neil, but since I'm probably going to have to take this engine apart, I'ld like to have access to it from all sides and be able to move it if necessary.I figure making the stand 3'6" high and 2'4" wide should be enough? What do you think?Here a pic of my engine: 35HP Mercury Outboard w/Controls
              • #8
                Hi Doc,Depending how many horses you have I lagged a 2 x 6 to the doorway of my shed.
                • #9
                  Dr Bones,I built one very similar to the one Rick built. I also have a 1986 35hp Merc. It has worked great. The only thing I would mention is to use a good size wheel. I used a 3" castor from Home Depot, I should have used 4". My basement floor is a liitle rough and it can be hard to move around. The castor has a swivel base that allows me to move the stand in any direction. If you want me to measure mine and give you dimensions I can. I would do it now, but I am at work.
                  • #10
                    I like that wood stand its cool. I have one I made out of steel (I have a welder). It has larger wheels so I can roll it around in gravel. I dont know how to post a picture on this site seems complicated. Best,Peter
                    • #11
                      Jollymon: Yes, please post the dimensions of your stand when you get around to it! Thanks for offering.FishonPeter, I have a buddy who suggested to help me make it out of scrap steel he has...but to be honest, I think it'll be easier and less of a hassle to saw and bolt 2"x4"sI went to Lowe's today..checked out some caster wheels. They seem cheap enough and would work for me. I don't plan pushing it around too much..and if so, then only on cement. The bigger wheels require some kind of axel or reinforcement to withstand the pressure. So, again: too complicated for me
                      • #12
                        Dr Bones,Tonight when I get home I will get the dimensions, The measurment that almost caught me was the width of the motor support, I had to have room for the trim rams. Get the largest castor wheels that Lowes has, with in reason, and get all four with swivles. They are good not only for moving it from place to place, but if you need spin the motor while you are working on it. It took me about 2 hours (including trip to Home Depot) to build mine, and about $35 in materials. I had the wood so I only had to buy nuts, bolts, wood screws, and the castors.
                        • #13
                          Dr Bones,Here it goes,The base is 23" wide 30" deep. The top of the motor mount to the bottom of the 2x4 base is 36".I mounted the uprights about 8" in from the end. Where the upright bolts to the base the upright is cut to about a 24 degrees angle.It tried to put some photos in but no luck. Here are the links:www.fishingworks.com/Users/UserFolders/njscuba/PhotoImages/ACF201F.JPG http://www.fishingworks.com/Users/Us...s/P1010002.JPG http://www.fishingworks.com/Users/Us...s/P1010004.JPG The lower unit is off of the motor, It is out for a presure check, but it fits fine, and I ca trim the motor up and down.Good luck. If you want more photos or detail give me a e-mail address and I will send more detail photos.
                          • #14
                            Thanks so much JollyMon! The measurements are almost the same as I had estimated. If you don't mind, I would very much appreciate any photos. Please send them here: j_jumpin@hotmail.com if you don't mind. Make sure it's not bigger than 1MB, otherwise it won't take it.Thanks again for your help!
                            • #15
                              Here is a pic of my stand I built a few years ago. I sandwiched 2x4s together for the legs, used 1/2 inch ply for strengh, and used 2x4s for the "transom". It sets on swiveling castors. The only thing I bought were the castors, the wood was scrap I had laying around. The Homelite weighs 230 pounds, and I have had my 270 pound Merc 1250 on it as well.
                              Project Skanky Beast http://70silverline.250free.com/Skankybeast.html
