boater1234
Master Chief Petty Officer
- Jan 6, 2010
- 869
Ok,I have a 1993 25hp 2 stroke mercury that I'm running at 50:1 and it smokes like a chimney. I know 2 strokes smoke,but I also notice so much unburnt oil/fuel coming from my exhaust which I know is normal as well. I'm not trying to start any oil war,etc,I'm simply going to ask a question here and I was hoping for real hard facts here. I know that it used to be 100:1 for omc then powerheads blew for lack of lubrication from sitting for periods of time then it went back to 50:1,I know all that good stuff.
My question is from reading a ton of forums it seems that amsoil 100:1 can be run in any 50:1 oil ratio outboard, what makes amsoil better than say full synthetic pennzoil or like full synthetic royal purple that only that oil can be run that lean but others can't. I personally believe imo 50:1 wastes allot of oil and 100:1 seems lean so 75:1 would be a perfect ratio. Please,this is just my opinion, nothing more. Now my motor doesn't sit either and never will so please keep that in mind. I think it runs a bit rough and smokes a ton and I decarbed already. If the amsoil will help with the smoke or it running a bit smoother as it claims would it be ok in my outboard. My outboard runs like a rapped ape but it imo smokes to much and idles a bit rough. I know I may have to fiddle with the fuel/air mixture screw because I just installed a new 25hp carb on my 20hp mec. Even before running at 50 to 1 seems so rich,any help on this??? Anything I can do to reduce allot of smoke and it running much smoother is my goal. It may just be the way it runs,who knows.
