Found this while rummaging through the depths of my boat storage. It seems to fit in the bottom holes of the transom bracket. Motor is a 90 Force. What is it for?
It's used for transporting like a transom saver device I believe. Over in the Chrysler/Force forum I've seen them talked about. I believe they are hard to find as well.
I don't have one for my Chrysler I use a regular type transom saver, but I also don't have powwr tilt and trim.
From what I found out I believe it is used to keep from trimming under too far if your transom has a huge angle. Put it in and motor only trims down to it.
Good to know. I do have a trim limitting bar, but it's just a single bar and has a catch on the end to hold it in the setting I want. Power tilt and trim are on my wish list, but the old Chrysler units are expenxive and problematic. I believe I will end up getting a CMC unit eventually.
We have that exact same devise Force 125hp, it makes sure the motor never drops when trailering.
We have T&T leak down so we have to use it, I would use it just to be safe,you don't want the skeg to hit something
