Pretty sure you already got your answer but figured I'd add my 2 cents. It's been my understanding that the zinc additive for oil, or special oil with higher amts. of zinc mixed in, are typically marketed as "break-in" oil. It's basically added insurance for when you start and run your
brand new/rebuilt engine, and helps protect from wiping any cam lobes, esp. for flat tappets (basically excludes most all modern or non-high performance vehicles/engines which today commonly use hydraulic rollers or OHC's).
After the break-in period is over though, it should be plenty safe to use a standard motor oil of your choosing or whatever is recommended from the manufacturer. Break-in oil is just that, don't really see why you should continue using it after, just wasting $$$. FYI - I have an older freshly rebuilt 1968 GM 250 inline 6, it has hydraulic flat lifters and am currently running this stuff from comp cams to break it in...see link. My engine doesn't have hardened ex. seats, but that has nothing to do with the oil. For insurance for that I mix in "leaded fuel replacement additive" into the gas, but from what Rick just said from his experience, this too might also be unnecessary ("old wives tale").
BOTTOM LINE: Is your engine already broken in and running fine on the SAE 30? No need for the special stuff, stick with what you know.
