- Mar 8, 2009
- 40,722
Picked up a prop shaft anode for my Bravo 3 years ago. It came in with a cone nut, hex screw and aluminum anode. Never did install it because after putting the rear prop on I only had 2 to 3 threads left. The new cone nut is not tapered to the degree the original nut is. Looking back the B3 nut has not changed since the B3 was released. So how is tis installed on the rear prop shaft?
Left to right = Original prop nut, cone nut, anode, hex screw
