enginesilo
- Jun 9, 2008
- 355
Curious what paint you all use for your outdrive? In the past I've always aerosol sprayed my alpha 1 gen 2 with Trilux, but it would wear off so last year I used Trilux in the can and brushed/rolled it on. I'd say about 90% of it has retained. I'm a salt water guy so top notch outdrive paint and anti-foul are a must.
In the areas where the paint has worn off, I can see the factory black paint that I scuffed up. Would it be ideal to scuff back up the touch up areas with a scour pad, use Primocon primer, and then put more Trilux back on top? I can't remember if I used Primocon primer before but I'm guessing I did.
Any tips on touching up will be great.
