acdc96
- Apr 23, 2013
- 412
while winterizing my 87 Mercruiser 260hp V8 with a gen1 alpha, when checking all the fluid levels I noticed the power steering fluid was a pink color [almost like pepto bismol]. obviously water was mixed in with the ATF Fluid from when the power steering cooler leaked. i fixed the cooler during the summer. im 99.99% sure the cooler is not leaking. i think their was was water in the system still when i fixed the cooler. this coming spring i want finish the boat and register it and launch it.
how would i go about flushing the power steering system?
[run the engine and disconnect the return line and stick it in a bottle and pour ATF Fluid into the resivor until fluid is a translusent red?]
*Note: no work will be done on my boat until mid march or april due to the cold temps in my area [currently 17 deg F and dropping below 0 at night]*
im just looking how to do it come spring time.
any other info needed i will post if asked.
