ericcarr2000
Ensign
- Mar 19, 2010
- 903
I will be replacing the drive anodes this spring. I've come across aluminum and zinc anodes. Which one is better?
So with me being the greatlakes, should I use the Zinc instead of the aluminum ones then?
So if Im reading it correctly then Ill need the Magnesium anodes then right?
How would aluminum anodes protect from corrosion while attached to aluminum outdrives ?
I don't understand how that would work.
