I am a confessed Nut Case with experimenting with all the Fuel claims.
I do not tend to believe anything that I can not demonstrate. Here is what I have been able to demonstrate.
An open container of gasoline does NOT attract water.
An open quart Jar of gas will evaporate the lighter components of the gas and ~1/4 of the jar will be gone in less than a week.
However it will not absorb water and turn milky white.
On open container of Gasoline will go bad (Gum Up) in less than a week due to exposure to the Oxygen in the air.
The amount of "Gum" can be evaluated by appearance. Fresh gas is Yellow tinted. Gummy gas is a darker amber.
Either storage method has its pros and cons.
The full tank has less air in the tank to form gums but leaves you with a lot of gas that has evaporated the lighter components.
The empty tank exposes the remaining fuel to much more Oxygen, but filling the tank with fresh gas dilutes the issue into oblivion.
My personal preference is to drain and store with a nearly empty tank.
A Simple test is to place a sample of gas in a container and shake it vigorously.
Fresh Gas will loose its foamy "Head" in under 5 seconds.
Gummy gas will hold its "Head" for very Much longer. Wet gas will be milky and opaque.
Watered, Normal and Gummed Gas.
I am about to take my 1996 searay 215 out for the season and will store it from Sept-April (8 months). It has a 50 gal fuel tank and I am wondering what's best to do with this tank? 1. Fill it with marine gas (non ethanol) and treat with some additive like sea-foam or sta-bil or 2. Leave it as close to empty for the 8 months and treat with Heat additive to remove water in spring when adding new fuel when getting ready to put it back in the water? Or is there a 3rd option better than the other 2?
I find it interesting that you go out of your way to ensure that you use Non-Alcohol Fuel and then plan to deliberately add Alcohol (Heat Additive) to solve a water problem that E-10 fuel would have prevented in the first place.
:joyous:
