ScooterMcTavish
- Mar 3, 2013
- 62
Hi Guys,
Finally had a chance to get out on a relatively calm lake yesterday, with 3/4 full gas tank and 550 lbs of people on my new to me Bayliner.
Running at WoT, I was able to get her up to 64.9 km/h which translates to almost exactly 40 MPH.
Question is, is this about as fast as I should expect/reasonably good performance for the boat/engine combo? Or would a change to prop help get a little more top end with a few less RPMs. Tach isn't working, but I'd guess somewhere in the mid 4's at WoT just based on noise.
In other considerations, the boat is mixed use, and its hole shot isn't bad for a piggy, underpowered fibreglass runabout. Getting a tube with 350-400 lbs of people up to plane takes a bit of work, but getting a waterskier up takes no effort. I seem to have a pretty good balance right now, but welcome others thoughts as to if I could see some improvement with prop changes, such as pitch, or 3 to 4 blade.
FWIW, the carb seems to be trimmed out about as good as we could get it.
