voodoochikin
- May 20, 2012
- 126
I decided to buy a remanufactured carb from a top seller of carbs "i5autoroca" on ebay. Their auction states that all parts are the highest quality, all internals are new, linkages are yellow zinc plated for corrosion protection, base is refinished, brass bushings installed in the throttle linkage to stop vacuum leaks, and casting plugs are epoxied.... So I ordered the one that replaced my particular carb number. My current carb has excessive play in the primary throttle shaft. The ebay carb shows up today. first off I notice that all the linkages, throttle plates, shafts, and casting just looks beat to hell. I then notice half of the linkages are bare steel and have surface rust. I then notice that two of the visible casting plugs do not have epoxy over them. Next I find that the throttle bores are knicked up pretty bad and the throttle plates don't seal all the way around. I then find that the little screws that hold the throttle plates on have not been pressed on the ends so they could loosen up and fall in the motor. I then that the carb does not have smooth operation, you can feel catches and rough spots. FINALLY I see no signs of any brass bushings in the throttle shafts, I can see daylight between the throttle shafts & bores AND there is tons of wiggle in the shafts. This carb is junk!! REFUND. what a waste of time. Now on the hunt for a solution.
SO, Should I look into a JET performance Q-jet as a direct replacement. OR go with a edelbrock 1409 and adapt it to fit?
