matthysone
- Jul 24, 2009
- 47
I decided it was time to do the alternator conversion on my 470 (serial #5641951). I looked at different pictures of how others had done this themselves to save some $$ and decided on the high mount method as I don't have p/s. I started by taking some measurements. In the above pic I will be using the timing cover bolts above the 20 and 14.25 mark and the open threaded hole above the 16.5 mark. This threaded hole above the 16.5 mark is the center point of the conversion project as the alternator will pivot here on a long 3/8" all thread or readi rod and all the other brackets land here as well to support the alternator.There is another bracket used to tension the belt that doesn't land here. (I needed longer bolts, a 5/16x3" bolt at the 20" mark and a 5/16x2.5" at the 14.5 mark and another 5/16x2.5 for attaching the belt tensioner bracket).
This pic shows the bolt location just to the left of the 2" mark that the belt tensioner bracket will be mounted to. Also the coil will have to be relocted up by the valve cover sharing a valve cover bolt.
The coolant reservoir tank and mount will have to be relocated. The two small hoses were long enough to relocate it to the rear and port side of the engine.
Critical measurement here of 4.5". I screwed in a temporary stud into the pivot hole(shown at the 15.5 mark) mentioned with the first pic and measured to each of the timing cover bolts that will be used. The other critical measurement is 3.625 (3-5/8) back to the other timing chain cover bolt.
