Prop Shaft HP for Mercruiser 165 inline 6
region4
Does anyone know how much shaft output a Mercruiser 165 inline 6 can muster? I see that Merc publishs this data for more modern 5.7 V8s, but can find nothing on the 165. I ask because I am trying to compare apples to apples, with respect to an engine upgrade.
180shabah
Re: Prop Shaft HP for Mercruiser 165 inline 6
Crank hp to prop hp difference on a single prop I/O is approximately 30 hp.
So you are starting with 135 at the prop on a NEW 3.7
region4
So, generally speaking a single alpha (or pre-alpha) I/O demands 30hp due to friction, etc. Good to know. Thank you.
A mercruiser 5.7 Vortec 4bbl puts out nearly twice that HP at the prop, which seems like a ton more power, albeit at the expense of 230 pounds of additional engine weight.
My boat goes 49mph (light load at WOT) with a strong Mercruiser 165 inline 6. What can I reasonably expect, in terms of mph, from a solid 5.7 vortec 4bbl?
achris
More fish than mountain goat
....My boat goes 49mph (light load at WOT) with a strong Mercruiser 165 inline 6. What can I reasonably expect, in terms of mph, from a solid 5.7 vortec 4bbl?
Probably around 60. Power requirements go up in the power of squares. ie, to double the speed requires the power to be squared.
Chris....
R.I.P. DonS
