I drained engine block and manifolds and poked wire to ensure drained. Will the water pump vanes hold in any water in the water pump or will they drain? Are the vanes/impeller in the water pump metal or rubber? I suspect metal and therefore there must be some clearance for water to drain around them. Is that why some people bump their engine via starter for a quick turn without starting?
Also, do you need to add any AF to the sump pump outlet or does it self drain?
