duped
- Aug 26, 2009
- 307
I have a 1986 merc 305, block, casting # 14088551, in need of replacement.
This motor sort of an odd-ball, because it has a one piece rear main seal, 14" flywheel (staggered starter), and yet it has the perimeter bolt valve covers. I knew all center bolt valve cover motors were one piece, but up until today I did not know there was a transition motor and that this 305 that has one piece seal, without center bolt covers.
MY ONLY QUESTION! Did the crank flange diameter change with the one piece rear seal, or at a later time...put differently, does my one piece rear seal 305 use the same flange pattern as 1987+ 350s, or the earlier pattern? I need to know because I am looking at 87-95 truck TBI 350s and need to know if I can retain my flywheel/coupler...
I know I will have to switch intakes and find one with the straighter center bolt holes, also am aware of needing electric fuel pump, core plugs, etc so I wont ask any silly questions about that. Gantry is built and motor is ready to be pulled.
