Re: 4.3L Mercruiser bellows
What does the bellows do ? If that is leaking will that put water into my boat ?
Which one are you referring to? There are 3 bellows on an Alpha style drive.
Uni Bellows (the biggest one) As FT said... If it leaks, yes, water in the boat, a lot of it!
Shift bellows (smallest, on the starboard side next to the Uni bellows). Allows the shift cable to move as the drive is turned. Will also allow water into the boat if it's damaged.
Exhaust bellows (medium size one below the Uni bellows). Directs exhaust and existing cooling water down through the drive exhaust path. Fills with water when the engine is not running. splits and tears are not a problem....
Chris........
