Re: Wear & Tear Comparison
I suspect I may be wrong in my understanding of engine wear & tear, but it seems that inboard gas engines get a lot more wear when compared to their automotive cousins. Is it reasonable to expect the same general life duration (in terms of engine hours) of a automotive engine in a car as it would see in a marine application ?
Probably. Marine engines usually run at constant RPM and power settings. Automotive engines are operated "all over the chart" But read on.....
Is the marine application that much more demanding on the basic engine components (excluding unique marine parts) ?
Absolutely! A marine engine, although operated at constant RPM for the most part........IS run at FAR higher load than just about ANY automotive engine.
Excluding medium & heavy duty trucks and certain light duty trucks that tow heavy loads, automotive (car/LT-truck) engines operate most of the time at a
SMALL fraction of maximum power & torque.
Marine engines almost ALWAYS operate at 50-75%-100% of maximum rated power (Just like an aircraft engine) This is not always a bad thing because (normal) oil temp, coolant temp, cyl-head temp etc is usually quickly achieved and the engine is run at those temps. (this promotes longevity) Automotive (car/lt truck) engines frequently DON'T get to normal operating temp before being shut down.
AND, Automotive (car) engines rarely get operated at maximum power (or even 50% power) for very long.
Clarification: If the same model engine was places in a automotive application and a marine application, under the same general loading characteristics (torque/RPM/start-stop cycles, etc), would the marine engine wear out first ? (assuming freshwater application)
Well, they are! (Automotive engines ARE operated in marine applications.) But I don't think you can easily equate the 2
I had a 66 Mark Twain that had a 150 Mercruiser installed (GM 230 cu-in 6-cyl) It ran largely "untouched" (other than normal maintenance) for 39 years before I sold it in 2005. (the hr meter failed in the mid 80's at 1500hrs.....)
If this is the case, what are the influencing factors ?
There's plenty of examples of old 50's cars and trucks with original engines that are still running....... I don't think there's a hard and fast "rule"...... just take care of it (don't let it freeze) and it'll last a "good long time"............
