Re: Volvo TAMD31 ok with duo prop?
Anything is possible with enough money and parts, but a lot depends on what was hooked to that drive before, and what the gear ratio. Then you will need the engine flywheel, flywheel housing, flexplate, exhaust tube to the drive, and may need some other types of engine changes.
