- Jul 18, 2011
- 17,711
There have been some posts in the past about outdrive stands of various configurations, some quite elaborate. Well there was someone on the Formula Boats that pieced together an outdrive stand using some dimensional lumber and a mover's dolly.
This gave me the inspiration to do a similar thing, except maybe a bit more robust.
So, I went to the big box lumber store and got a couple of moving dollies . . . good to 1,000 lbs. Then I scrounged around the garage for some lumber and came up with some 2x12's remnants and some 2x4's
The big box store only had 1 of the less expensive wooden dollies in stock, so I had to go a bit up-scale on the dollies as that was all they had.
I did some measuring of the outdrives as they sit on the boat, and then cut the wood up into a bunch pieces, screwed them together and came up with these things
I wanted them to be about the height that the ventilation plate of the outdrive sits above the ground.
Here they are tucked under the outdrives.
I used to use a 2-wheeler to bring the drives over to the boat and them lift them into place in order to install them . . . and pretty much the reverse process when I took them off . . . sometimes things worked out better than others. I think they weight about 170 lbs . . . as they are Bravo 3's
Taking the outdrive off is soooo much easier with these stands . . . The outdrive rests on the stand while I unbolt everything, and then just a good 'yank' and the outdrive and stand come along.
These will be easier to store for the winter . . . I used to lift them off of the 2-wheeler and flip them upside down and set against a wall, just for safe keeping.
I think it will be easier to store them and prep them for next season with these dollies.
Total cost, since I had the lumber on hand, was $35 each. :thumb:
