Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Out Drive Identification Help
  • Out Drive Identification Help
    Boat is a 1970 Gibson 36' with a Mercruiser 225HP 302 installed. Clearly the out drive is toasted thanks to electrolysis that got it so bad there are holes and pieces missing. I need help identifying exactly what the out drive is so I can find a replacement. Thanks all in advance!
    You can see the bearing carrier.
    View my restoration thread at:
    http://forums.iboats.com/forum/boat-...youtube-videos
    View my Youtube video series at:
    https://www.youtube.com/watch?v=1bKq...7RHznlac0Y6-pu
    No plate on motor? Its pre-alpha, --- http://www.sterndrives.com/merc/rdriveid.html
    • #3
      Ayuh,.... It's a TR/ TRS drive,.... Been outa production for many years,....
      • #4
        I would pull the ford motor and all the drive components, then drop in a 6.2/bravo package
        1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
        Past Boats
        1970 Wooster Hellion - Merc 9.8
        2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
        1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
        What’s behind you doesn’t matter.Enzo Ferrari
        • #5
          Is it possible to find a TR/TRS drive on eBay or anything anymore?
          6.2 Bravo package.... motor/drive/everything? Any idea if the transom holes are the same or would I need to redo the transom as well? Not that it matters much, just wanting to know what can of worms I'm opening up.
          • #6
            transom key is same, later drives have two extra holes that you need to drill.
            it may be possible to find and old TR/TRS drive, then rebuild it, however it may be cheaper to go with something built 40 years newer. it will definitely be faster to find a late-model wrecked boat
            Past Boats
            • #7
              Although there is a TRS on ebay right now http://www.ebay.com/itm/Mercruiser-T...-/150874515176
              Past Boats
              • #8
                Funny, I saw that TRS on there and barfed at the price. Gotta pay to play though, I get that. That is just the outdrive though and ideally I'd like to get the gimbal ring and housing and the bell housing, basically everything outside the transom.
                • #9
                  you should price a rebuilt Volvo Penta 290DP
                  Past Boats
                  • #10
                    Nope,.... Different hole,.... The TR/ TRS is a bigger hole, much like the older Volvo transom holes,.....
                    Smaller than an OMC Stringer hole, but bigger than the now industry standard,....
                    • #11
                      learned something today..... I thought the TRS used the same hole as the MC1.... guess not.
                      Past Boats
                      • #12
                        here is a trs transom assembly https://www.shipwrecksalvage.net/mer...a3-p-5338.html
                        Past Boats
                        • #13
                          Ayuh,.... It's almost exactly the same as the old Volvo large cut-out,....
                          Matter of fact, there's an adapter plate out there for closin' in the Volvo/ TR hole to the standard Merc cut-out, for 'bout a grand,..
                          I've seen Bob use that adapter for both,...
                          • #14
                            There was a question raised amongst friend that perhaps I could use an alpha 1 gen 1. Any truth to that?
                            • #15
                              based on what Bondo is saying.....no
                              the choices are fix the transom and move to either an Alpha or Bravo or stay with the TRS drive or get the adapter
                              that adapter plate that Bondo references in post #13 is required if it is the one for adapting a Volvo AQ / BMW hole to an Alpha/Bravo. the Mercruiser part number is 827691a1 and it is between $600 and $1100 depending on where you get it. Mercruiser is cheapest
                              here are a few links
                              http://www.marinedepo.com/product-details.php?id=178
                              http://www.crowleymarine.com/parts/264393.cfm
                              https://www.*****************/parts/m...drive-827691a1
                              http://www.mercruiserparts.com/82769...plate-kit-tran
                              Past Boats
