I happen to have a 60's inboard setup that I vision putting MPI on
Ayuh,.... What motor,..??
It'll probably be easier to swap in a more recent motor, than to put Mpi on yer ole motor,...
Howdy,
Yeah, I don't think you'll be doing EFI on that corvair nor would it get you any real benefit anyway.
EFI is great if a boat comes with it, Or you can find an engine already equipped with EFI, Adding it later is pretty much not worth it.
FYI - These boats have an issue at higher RPMs and worse if you run them that way for a long time. They lean out - due to the pressurized engine compartment. For years now there have been EFI setups made for the Corvair engine. I picture FI eliminating the lean issue at high RPMs and aiding in better fuel consumption at the same time. With the use of an O2 sensor it will keep the fuel mixture in the sweet spot all the time.
Pressurized engine compartment? What kind of boat is this? That makes no sense at all, not to mention sealing an engine compartment would be very, very hard to do.
Sam, I might sell my original Wayne 100 that has been stored inside most if not all of its life. I am also looking into museums willing to display it so more people can learn about all that went into the design and making it work. If I end up keeping it, I have already found one museum interested in displaying it. However, today I found out that my insurance company is not willing to insure it if it is in the museum.
