cooterdude
- May 27, 2010
- 33
bought a 1989 four winns sundowner off of Craigslist with a bad motor
found a used motor on Craigslist and swapped all my marine internals into the old block
got the engine installed and went to put the out drive on omc cobra btw
found out you have to remove clutch pilot bearing from crankshaft for an out drive to work
now i have to pull bell housing back off as well as the engine coupler so i can remove the pilot bearing from the crankshaft of the "new" motor
