I have a 2016 Mercruiser 8.2 MAG CAT DTS with Bravo 3 outdrive- purchased brand new, has 6 months in salt water. When I removed the props for the first time there was a blue taffy-like lubricant on the shaft splines that I need to purchase when re-installing the props. The ambient temperature was 28 degree F when I removed the props which may have made the lubricant taffy-like. Wondering what the Mercury part number is of the lubricant?? Mercury recommends the 3 following Mercury lubricants for the prop shaft, I want to purchase the same.
#34 Special Lubricant 101 p/n-92-802865Q02
#94 Anti-Corrosion Grease p/n-92-802867Q 1
#95 2-4-C Marine Lubricant p/n-92-802859A 1
