Hey guys, winterized my boat and drained a little of the gear lube from the bottom of the outdrive. Are those spots of little lighter lube water? Should I drain the gear lube to make sure it doesn't crack the outdrive if it has water in it?
This whole season I would loose a couple ounces of gear lube every 5 hours so always just topped off.
