- Jul 23, 2011
- 47,306
working on my BBC build and have been vacillating with whether or not to add an oil cooler. the Gen VI block has two oil cooler ports in it and would make plumbing an oil cooler a breeze. I would put one in the supply hose to my crank mounted raw water pump, and have identified the oil cooler I would use.
however, does the motor really need an oil cooler?
those running oil coolers, have you monitored the oil temps? just curious.
