I'm purchasing a boat with twin 5.7 Crusader Captains Choice MPI motors with very low hours. Part of the deal was the seller would have crusader go over the motors. It just so happened in the few days from when I looked at the boat and sea trialed to the time crusader got their hands on it, one motor developed an issue. The boat ran great at idle and you could even bring her up to WOT. Once backed down the motor would stutter and stall out, and would not start unless left alone for at least 20 min. Sounds like a fuel problem. Tank cleaned (I doubt this was the issue, as only 1 motor had the problem, but at least I know the tank is clean now), all filters changed despite looking clean and only had about 20 hours on them, pressure tested fuel pumps and checked ok at the dock. When testing pressure under load, the pressure dropped on the HP pump. When touching the strainer she was hot. the other motor which ran fine was cool to the touch. Mechanic said the HP pump is raw water cooled off the riser. Pulled the hose from the riser and sure enough, no water. Cleared the clog in the riser and put back together. Now everything checks out fine.
I have a few concerns:
1. I cannot find a diagram in any of the crusader books showing a raw water hose from the riser to the fuel pump (Motors were done in 2007, but I do not have the serial numbers to confirm the year of the motor)
2. Even if the HP pump is raw water cooled, wouldn't no water damage the pump?
3. Shouldn't the risers be changed? I've never hear of cleaning the riser. When they fail, they usually need to be replaced.
Seems like a simple but PIA to diagnose problem. At the same time, I want to make sure everything checks out before I take delivery.
