dlogvine
Master Chief Petty Officer
- May 4, 2015
- 832
Kinda lame question, but wondered how often should I change the oil in the Bravo 1 outdrive and how often should I change the impeller/gaskets in the water pump. This is my friends boat and he said it was serviced last year before the season started. The boat was kept outside in Arizona, so the temperatures in summer are going up quite a bit.
Same question for Alpha II outdrive. I purchased the boat with Alpha II outdrive, looked like the engine oil was new, very clean, but dont know how long ago was the outdrive serviced. Is there any way to determine if I should change the fluids and the impeller in this outdrive without taking it apart?
Thank you.
Thank you.
