I have a Regal Commodore , 2860 model with twin Volvo 4.3 engines
Kohler 5.A generator mounted along side port engine .
Seldom using generator, would start at times too keep parts moving.
Other day it fired up, ran 5 minutes , sounded like it was starving for fuel, running ruff, Stalling
Number of times it ran few minutes . choked stalled .
Can see generator , but because of port engine can not get too anything
Fuel
Generator run off of main gas tank for boat engines. I use boat weekly and fuel is fresh
Hoping for the easy basic fix changed two gas filters,
In line canister. ( gas was clean )
small metal inline filter screwed into generator .
NO LUCK
Started ran few minutes, stalled
OIL LEVEL IS GOOD
Reaching out too fellow boaters with same generator that has possibly experienced similar issue
I can see areas of generator but impossible too get too oil filter or spark plug with out removing manifold of port engine .
Any ideas ??
Fuel
NO LUCK
OIL LEVEL IS GOOD
Any ideas ??
