- Jul 18, 2011
- 17,711
I bought (via iBoats ) a few cans of Mercury Power Tune to de-carb my various engines. I got the Mercury stuff, as a slew of web postings favored the results over SeaFoam and the similar decarb products.
When the Power tune arrived (thanks again iBoats) I noticed that on the can it says that it can be used for both carb'ed and fuel injected engines. The detailed instructions on the can only reference carbureted engines, i.e. squirting the stuff down the carb, etc.. There are no specific instructions for fuel injected engines. I have always thought that fuel injected engines would not want the stuff sprayed into the throttle body :noidea:
Here is a pic of the can showing the statement on the front "Use in all 2- and 4- cycle carbureted and fuel injected gasoline engines"
So, I'm not sure anyone will know, but I thought that I would post the question for thoughts/comments, or if anyone has used this stuff on a fuel injected engine.
I got my old Merc 7.5 hp . . . my less old Johnson 4 hp to de-carb . . . and then my 2004 Ford Explorer is running a bit rough so I thought I would use a can on it as well ( I bought 3 cans) But the Expy is MPI, so I'm not sure it will mess things up by spraying in the throttle body.
