Rranger
- May 18, 2009
- 420
I have a 5.7 L with a closed cooling system and a 25 hp outboard kicker. I plan on fishing later this fall in possibly freezing weather. My concern is when I pull the boat out of the water do I do the following.
1) Put both outdrive and outboard in the full down position and allow to drain ? Turn over both engines without starting to empty out impellers ?
2) Drain manifolds, I installed quick drains on the stern sides at the lowest point.
3) Do I need to drain the fresh water supply line from the impeller to the engine?
Am I missing anything?
For what it's worth it's all inland fresh water fishing.
Thanks for any pointers, tips.
