hawkhunter
- Jul 20, 2015
- 12
Recently bought a '91 Cajun with a 1991 Mercury 75hp outboard. Took it out on the lake, ran great but while going through the no wake zone the overheat alarm sounded. Upon giving it just a little speed the alarm would stop. Apparently just at idle the motor gets hot. Replaced the impeller with a new one. The old impeller was not broken or burnt. Took it back on the water, same problem. This time I replaced the thermostat, poppet valve, and installed a complete impeller kit including the pump housing. Upon starting I got a decent tell-tale for a few seconds, then none and it eventually sounded the overheat alarm again. I monitor the temp with my infrared gauge and shut it down before any damage can occur.
It appears water is not traveling throughout the cooling system like it should. When I pull the thermostat/poppet cover it appears dry except for a little condensation on the t-stat.. The motor itself has only been a freshwater motor and there is no gunk or sediment build up at all. It's a very clean motor. Compression is about 120 on all 3 cylinders. I'm really at a loss here. I've flushed the system, including the tell-tale, with water and air and still nothing. I've verified the thermostat is working properly and since the motor seems fine at speed I assume the poppet is working properly.
I boat on a chain of lakes with many no wake zones so this issue makes the boat unusable. What am I missing? I can't seem to find the answer after hours of searching. I have a Clymer manual but that hasn't provided any answers either. Any help or ideas?
